소개
Use this guide to disassemble the Toshiba A1304T.
If you can't get a hold of a Torx 6 Security Screwdriver, a small flathead can be used as a substitute
필요한 것
Open the phone so that it matches the photos to the left.
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
