주요 콘텐츠로 건너뛰기
Disassembling Toshiba NB205 N330PK Back Panels
필요한 것
  1. Disassembling Toshiba NB205 N330PK Back Panels, Disassembling Toshiba NB205 N330PK Back Panels: 1 단계, 이미지 2개 중 1개 Disassembling Toshiba NB205 N330PK Back Panels, Disassembling Toshiba NB205 N330PK Back Panels: 1 단계, 이미지 2개 중 2개
    • Using the Phillips #0 in the bit driver, carefully loosen and remove the single 5mm screw.
    • With the retaining screw removed, lift the panel upwards to separate it from the netbook.
  2. Disassembling Toshiba NB205 N330PK Back Panels: 2 단계, 이미지 2개 중 1개 Disassembling Toshiba NB205 N330PK Back Panels: 2 단계, 이미지 2개 중 2개
    • To replace the panel, do step 1 in reverse:
    • Align the panel slots in the appropriate grooves and set in place.
    • With the bit driver, replace the screw to secure the RAM panel.
  3. Disassembling Toshiba NB205 N330PK Back Panels: 3 단계, 이미지 2개 중 1개 Disassembling Toshiba NB205 N330PK Back Panels: 3 단계, 이미지 2개 중 2개
    • Using the bit driver and the Phillips bit, remove both of the panel's retaining screws.
    • With the screws removed, lift the panel in the designated direction, as depicted in photo, for removal.
    • The hard drive is located beneath this cover and is now accessible.
  4. Disassembling Toshiba NB205 N330PK Back Panels: 4 단계, 이미지 2개 중 1개 Disassembling Toshiba NB205 N330PK Back Panels: 4 단계, 이미지 2개 중 2개
    • To replace the hard drive panel, do step 3 in reverse:
    • Place the panel back in its original position and press down.
    • If the hard drive was removed or replaced during this process, improper installation may prevent the hard drive panel from sitting in the slots properly.
    • With the bit driver and Phillips bit, replace the two retaining screws to secure the cover plate in place.
결론
작성자
5다른 기여자 명과 함께
Mason McCaskill
회원 가입일: 10/18/13
1,021 평판
안내서 9개를 작성함
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 회원
CLEM-BENSON-F13S14G2
3 회원들
안내서 27개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 1,066
