주요 콘텐츠로 건너뛰기
Disassembling Western Digital Elements SE HD case and mainboard
필요한 것
  1. Disassembling Western Digital Elements SE HD case and mainboard, Opening the case: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • The case can be opened easily with a plastic case opening tool. Strong finger nails and an old credit card / plastic card may work too.
  2. Disassembling Western Digital Elements SE HD case and mainboard, Remove marked screws (T5): 2 단계, 이미지 1개 중 1개
    • The 5 marked screws can be removed with a Torx T5.
  3. Disassembling Western Digital Elements SE HD case and mainboard, Lift up the board: 3 단계, 이미지 2개 중 1개 Disassembling Western Digital Elements SE HD case and mainboard, Lift up the board: 3 단계, 이미지 2개 중 2개
    • Lift the board gently - there is only one small connector connecting the board to the hard disk case (around the yellow market space).
    • On the second image, you can see the board turned over.
    • Further disassembly would damage the disk. I hoped to find a SATA connector within, but maybe someone knows an alternative board with the same connector.
  4. Disassembling Western Digital Elements SE HD case and mainboard, Hard disk labels and case labels: 4 단계, 이미지 2개 중 1개 Disassembling Western Digital Elements SE HD case and mainboard, Hard disk labels and case labels: 4 단계, 이미지 2개 중 2개
    • The label on the WD Elements SE case and the labels on the harddisk can be seen here. I censored serial numbers, the WWID and the barcodes.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Bastli
회원 가입일: 12/30/23
283 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 25
지난 30일: 110
전체 시간: 1,653
