주요 콘텐츠로 건너뛰기
Disassembling Wii Balance Board
필요한 것
  1. Disassembling Wii Balance Board, Floor Unit: 1 단계, 이미지 1/1
    • Unscrew these #1 Philips screws, and leave them in the plastic foot holders.
  2. Disassembling Wii Balance Board: 2 단계, 이미지 1/1
    • Remove the foot holders and place them on the side
  3. Disassembling Wii Balance Board: 3 단계, 이미지 1/1
    • Remove the four feet and place them on the side
  4. Disassembling Wii Balance Board: 4 단계, 이미지 1/1
    • Remove these #1 Philips screws, and leave them in their counterbores
  5. Disassembling Wii Balance Board: 5 단계, 이미지 1/1
    • Lift grey shell off and place to the side to reveal:
    • ADC and Logic board
    • Bluetooth module
    • Strain gauges
    • Battery holder
  6. Disassembling Wii Balance Board: 6 단계, 이미지 1/1
    • The ADC and Logic board contains:
    • Bluetooth module
    • Power button connector
    • Battery and sync button connector
    • Strain gauge wheatstone bridge connections
    • The topmost connection for each of the four bridge connections is the ground; relative to this, the two middle connections should be at 1.2 VDC, and the bottom should be at 2.7 VDC
결론
다른 15명이 해당 안내서를 완성하였습니다.
Pete Marchetto
회원 가입일: 01/25/11
667 평판
안내서 2개 작성하였습니다
댓글 5개
Great stuff Pete, being able to fix the wifi board got me mucho street cred with " her indoors " and lots of other goodies that go along with that
HENRY - 답글
Can I take out the battery box without removing the bottom?
Richard Merchant - 답글
No, you can't. You will have to follow this procedure completely.
paulo lima -
Thank you! I was able to fix our 10 year old balance board.
the kids think I’m a roakstar, for now anyway.
lisadubya - 답글
is there schematics for the power pcb
Josué Hernandez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 34
전체 시간: 12,197
