주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Continue sliding the spudger along the perimeter of the left grated face of the Xbox. Pull the top panel off. Pull the top panel off.
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
    • Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Slide the spudger along the crevice to separate the grated face and the top body. Slide the spudger along the crevice to separate the grated face and the top body.
    • Slide the spudger along the crevice to separate the grated face and the top body.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate. Slide the spudger along the crevice, going completely about the perimeter of the bottom panel. Pull the bottom panel off.
    • Wiggle the spudger in the crevice as you slide the spudger to loosen the bottom plate.
    • Slide the spudger along the crevice, going completely about the perimeter of the bottom panel.
    • Pull the bottom panel off.
  7. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off. In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off. In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
  8. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go. Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go. Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
  9. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands. Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser. Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
  10. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open. Locate the other clip and insert the spudger to remove it. Locate the other clip and insert the spudger to remove it.
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
  11. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Continue to run the spudger along the crease to release any further clips that may still be attatched. Do no pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do no pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
  12. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Find the brown section where the ribbon  cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon. Find the brown section where the ribbon  cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon. Find the brown section where the ribbon  cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
  13. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device. Lift the bottom body slightly away from the core at a 45 degree angle. Lift the bottom body slightly away from the core at a 45 degree angle.
    • Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
    • Lift the bottom body slightly away from the core at a 45 degree angle.
  14. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Rotate the Xbox so you are now looking at the back of the device. This step of disassembly requires the removal of the warranty sticker.  This will void your warranty.  Check the main page for a link to warranty information from Microsoft.
    • Rotate the Xbox so you are now looking at the back of the device.
    • This step of disassembly requires the removal of the warranty sticker. This will void your warranty. Check the main page for a link to warranty information from Microsoft.
    • Remove the sticker from the back of the Xbox.
    • The sticker is not needed for reassembly.
  15. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Turn the Xbox to the left to locate the clip holding the body together. With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way. With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
    • Turn the Xbox to the left to locate the clip holding the body together.
    • With a spudger, press up on the clip like a latch. Move to the far end to undo the other clip the same way.
  16. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this. Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
    • Push the spudger into the crevice. Slide the spudger along the vertical crevice to detach the last clip. The bottom body should slide off after this.
결승점
Sarah
회원 가입일: 2014년 01월 30일
1,534 평판
안내서 4개 작성하였습니다
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G11
4 회원들
안내서 31개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 67
