주요 콘텐츠로 건너뛰기
Disassembling Xbox 360 E Top Panel
필요한 것
  1. Disassembling Xbox 360 E Top Panel, Top Panel: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Spudger
    $2.99
    구매
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Disassembling Xbox 360 E Top Panel: 2 단계, 이미지 1/1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Disassembling Xbox 360 E Top Panel: 3 단계, 이미지 1/3 Disassembling Xbox 360 E Top Panel: 3 단계, 이미지 2/3 Disassembling Xbox 360 E Top Panel: 3 단계, 이미지 3/3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jennifer
회원 가입일: 02/02/14
1,909 평판
안내서 4개 작성하였습니다
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 회원
CPSU-AMIDO-W14S2G11
4 회원들
안내서 43개 작성하였습니다
댓글 한 개
I broke my spudger! May I use anything besides that?
Colin2 Schrek - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 32
전체 시간: 2,485
