주요 콘텐츠로 건너뛰기
Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard
필요한 것
  1. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard, Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: 1 단계, 이미지 1/1
    • Insert wisdom here.
    Same with me. Better try to use a sharp knife around the edges of the black cover and carefully lift it, holding the knife flat. Do not bend too strongly or you will crack the thin glass/plastic cover.
    weberguy - 답글
  2. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: 2 단계, 이미지 1/1
  3. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: 3 단계, 이미지 1/1
  4. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: 4 단계, 이미지 1/1
  5. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: 5 단계, 이미지 1/1
  6. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: 6 단계, 이미지 1/1
  7. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: 7 단계, 이미지 1/1
  8. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: 8 단계, 이미지 1/1
  9. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: 9 단계, 이미지 1/1
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jonathan J
회원 가입일: 02/07/14
201 평판
안내서 1개 작성함
댓글 4개
I tried to open the black part but has cracked with the minimum attempt. Now I have broken the front glass with the black part.
melchorct - 답글
Historia, I cracked black glass (camera). where one can buy ? thanks
kamykazeandy -
same thing happened with me
but at least i was able to open it.
i have unplugged the battery fr long time but still not working, any suggestions???
nimer76 -
Same happened to me with the black camera cover. Do you guys found a replacement?
renehahn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 7,408
