주요 콘텐츠로 건너뛰기
Disassembling ZTE Racer II Phone
필요한 것
  1. Disassembling ZTE Racer II Phone, Phone: 1 단계, 이미지 1/1
    • Carefully prise the back cover off the phone.
  2. Disassembling ZTE Racer II Phone: 2 단계, 이미지 1/1
    • Remove Battery, SIM Card, and MicroSD
    • Remove the four screws located around the edge of the case. They should be very small phillips heads.
  3. Disassembling ZTE Racer II Phone: 3 단계, 이미지 1/1
    • Using a flathead screwdriver, carefully prise the black plastic away. It's held in with a series of clips, and should come away easily.
  4. Disassembling ZTE Racer II Phone: 4 단계, 이미지 1/1
    • Carefully remove the ribbon cable that connects the capacitive screen to the main board. You need to carefully lift the small tab, then pull the cable out.
  5. Disassembling ZTE Racer II Phone: 5 단계, 이미지 1/2 Disassembling ZTE Racer II Phone: 5 단계, 이미지 2/2
    • Now using the flathead screwdriver, prise the plastic that makes up the front, away from the circuit board. Like the back piece, it has a series of clips around the edge, and should lift free without much effort.
  6. Disassembling ZTE Racer II Phone: 6 단계, 이미지 1/2 Disassembling ZTE Racer II Phone: 6 단계, 이미지 2/2
    • There you have it. Amazingly simple to take apart this phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob
회원 가입일: 04/27/13
121 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,833
