주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. iClicker 수리는 자사의 서비스 설명서를 사용하세요.
  1. Disassembling iClicker Device, Disassembling iClicker Device: 1 단계, 이미지 1개 중 1개
    • Behold the iclicker in all its interactive and educational beauty.
  2. Disassembling iClicker Device: 2 단계, 이미지 1개 중 1개
    • Place the device on a flat surface, buttons facing down.
    • Remove the battery cover and the three batteries within.
  3. Disassembling iClicker Device: 3 단계, 이미지 2개 중 1개 Disassembling iClicker Device: 3 단계, 이미지 2개 중 2개
    • Remove the two visible screws using a #00 Phillips screwdriver.
    • Oops! Don't forget a hidden third screw beneath the factory label.
    • Peel back the corner of the label to reveal the hidden screw.
    • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
  4. Disassembling iClicker Device: 4 단계, 이미지 2개 중 1개 Disassembling iClicker Device: 4 단계, 이미지 2개 중 2개
    • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
    • For the more resistent iclickers, a spudger may be employed to separate the pieces.
  5. Disassembling iClicker Device: 5 단계, 이미지 1개 중 1개
    • Your iclicker is now exposed for all its worth.
    • The back panel can be set aisde, as the remaining components are housed in the front panel.
  6. Disassembling iClicker Device: 6 단계, 이미지 2개 중 1개 Disassembling iClicker Device: 6 단계, 이미지 2개 중 2개
    • Using a spudger, gently pry the battery connectors from the front panel.
  7. Disassembling iClicker Device: 7 단계, 이미지 1개 중 1개
    • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
  8. Disassembling iClicker Device: 8 단계, 이미지 1개 중 1개
    • The buttons can be easily removed from the front assembly sans spudger.
  9. Disassembling iClicker Device: 9 단계, 이미지 1개 중 1개
    • Don't lose the small LED cover sitting precariously in the front panel.
  10. Disassembling iClicker Device: 10 단계, 이미지 1개 중 1개
    • Your iclicker is now disassembled.
작성자
4다른 기여자 명과 함께
Brady Cabe
2,743 평판
안내서 2개를 작성함
1가이드 댓글
What is an iClicker ?
furbies - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 8,000
