주요 콘텐츠로 건너뛰기
Disassembling iPhone 4S Back Camera
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Disassembling iPhone 4S Back Camera, Disassembling iPhone 4S Battery: 1 단계, 이미지 1/1
    • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
  2. Disassembling iPhone 4S Back Camera: 2 단계, 이미지 1/1
    • Push the back glass towards the top of the phone.
  3. Disassembling iPhone 4S Back Camera: 3 단계, 이미지 1/1
    • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
  4. Disassembling iPhone 4S Back Camera: 4 단계, 이미지 1/2 Disassembling iPhone 4S Back Camera: 4 단계, 이미지 2/2
    • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
    • Using a plastic opener tool, pry up the battery connector.
  5. Disassembling iPhone 4S Back Camera: 5 단계, 이미지 1/1
    • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Then, out pops the battery.
  6. Disassembling iPhone 4S Back Camera, Disassembling iPhone 4S Back Camera: 6 단계, 이미지 1/1
    • Unscrew the 4 phillips screws holding the shield covering 6 of the 8 connectors.
    • Make sure to keep track of which screws are which, they very by tenths of a millimeter.
  7. Disassembling iPhone 4S Back Camera: 7 단계, 이미지 1/2 Disassembling iPhone 4S Back Camera: 7 단계, 이미지 2/2
    • Using a plastic opening tool, pry the back camera connector from the logic board.
    • Be careful not to lose the small square peice of plastic covering the bottom of the camera, it comes off very easily.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Chandler Skinner
회원 가입일: 10/15/11
3,710 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 12
전체 시간: 2,688
