주요 콘텐츠로 건너뛰기
Disassembling iPhone 4S Vibrator
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Battery: 1 단계, 이미지 1/1
    • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
  2. Disassembling iPhone 4S Vibrator: 2 단계, 이미지 1/1
    • Push the back glass towards the top of the phone.
  3. Disassembling iPhone 4S Vibrator: 3 단계, 이미지 1/1
    • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
  4. Disassembling iPhone 4S Vibrator: 4 단계, 이미지 1/2 Disassembling iPhone 4S Vibrator: 4 단계, 이미지 2/2
    • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
    • Using a plastic opener tool, pry up the battery connector.
  5. Disassembling iPhone 4S Vibrator: 5 단계, 이미지 1/1
    • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Then, out pops the battery.
  6. Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Logic Board: 6 단계, 이미지 1/1
    • Disconnect the antenna cable from the logic board.
  7. Disassembling iPhone 4S Vibrator: 7 단계, 이미지 1/1
    • Unscrew the 2 phillips screws holding the shield covering the dock connector ribbon.
    • One of the screws is .2 millimeters longer than the other.
  8. Disassembling iPhone 4S Vibrator: 8 단계, 이미지 1/2 Disassembling iPhone 4S Vibrator: 8 단계, 이미지 2/2
    • Disconnect the dock connector ribbon from the logic board.
    • Pull the cable up and flow it to the side.
  9. Disassembling iPhone 4S Vibrator: 9 단계, 이미지 1/2 Disassembling iPhone 4S Vibrator: 9 단계, 이미지 2/2
    • Unscrew the 4 screws holding the large shield and the single screw holding the small shield.
  10. Disassembling iPhone 4S Vibrator: 10 단계, 이미지 1/1
    • Using the plastic opening tool, pry up the 7 connectors on the top of the logic board.
    • The back camera will come out, make sure you get the small piece of black plastic covering the back of the camera.
  11. Disassembling iPhone 4S Vibrator: 11 단계, 이미지 1/2 Disassembling iPhone 4S Vibrator: 11 단계, 이미지 2/2
    • Unscrew the 2 flat head screws.
    • Unscrew the 3 phillips head screws, the top one is covered by a small piece of black tape.
  12. Disassembling iPhone 4S Vibrator: 12 단계, 이미지 1/1
    • Using your fingers or a plastic opening tool carefully pull out the logic board.
  13. Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Vibrator: 13 단계, 이미지 1/2 Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Vibrator: 13 단계, 이미지 2/2
    • Pry the vibrator up off the metal.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Chandler Skinner
회원 가입일: 10/15/11
3,710 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 2,483
