이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
Then, out pops the battery.
Unscrew the 2 phillips screws holding the shield covering the dock connector ribbon.
Disconnect the dock connector ribbon from the logic board.
Pull the cable up and flow it to the side.
Unscrew the 4 screws holding the large shield and the single screw holding the small shield.
Using the plastic opening tool, pry up the 7 connectors on the top of the logic board.
Unscrew the 2 flat head screws.
Unscrew the 3 phillips head screws, the top one is covered by a small piece of black tape.
Using your fingers or a plastic opening tool carefully pull out the logic board.
다른 2명이 해당 안내서를 완성하였습니다.
