주요 콘텐츠로 건너뛰기
Disassembling of Wahl Lithium Ion Trimmer
필요한 것
  1. Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: 1 단계, 이미지 2개 중 1개 Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: 1 단계, 이미지 2개 중 2개
    • Begin by removing the rubber grip along the handle.This can be done by using a thumbnail, pick or similar tool to pry up the upper edges on both sides sufficiently to grasp and pull them downwards, essentially turning it 'inside out' as you might a tight, wet stubborn sock.
  2. Disassembling of Wahl Lithium Ion Trimmer: 2 단계, 이미지 1개 중 1개
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Disassembling of Wahl Lithium Ion Trimmer: 3 단계, 이미지 2개 중 1개 Disassembling of Wahl Lithium Ion Trimmer: 3 단계, 이미지 2개 중 2개
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
nathan
회원 가입일: 10/22/13
1,440 평판
안내서 6개를 작성함
5가이드 댓글
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
Andrew Beeson - 답글
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful.  Thank you so much
tundraorchid - 답글
Thanks…worked well.
Magpie - 답글
You open the clipper by using small flat head on the 4 tabs on the handle
JOSH - 답글
When attempting to clean the unit, I removed the razor heads and everything fell out that I wasn't holding. How do I get them back and in what positions?
Patrick Serle - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 39
지난 30일: 136
전체 시간: 46,065
