주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Disassembling of Wahl Lithium Ion Trimmer
필요한 것
  1. Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: 1 단계, 이미지 1/1
    • Begin by removing the rubber grip along the handle.
  2. Disassembling of Wahl Lithium Ion Trimmer: 2 단계, 이미지 1/1
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Disassembling of Wahl Lithium Ion Trimmer: 3 단계, 이미지 1/1
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
  4. Disassembling of Wahl Lithium Ion Trimmer: 4 단계, 이미지 1/1
    • Here is the final result. This gives access to the switch button, chip set, battery and motor.
결론
다른 12명이 해당 안내서를 완성하였습니다.
nathan
회원 가입일: 10/22/13
1,395 평판
안내서 6개 작성하였습니다
University of Maryland, Team 1-3, Shastany Fall 2013 University of Maryland, Team 1-3, Shastany Fall 2013 회원
UMD-SHASTANY-F13S1G3
3 회원들
안내서 6개 작성하였습니다
3 댓글
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
Andrew Beeson - 답글
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful.  Thank you so much
tundraorchid - 답글
Thanks…worked well.
Magpie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 67
30일 전: 297
전체 시간: 40,289
