이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the screws from the top to take the metal piece and plastic part off.
Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 3개
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful. Thank you so much
