주요 콘텐츠로 건너뛰기
Disassembling the Canon PowerShot A200 Case
필요한 것
  1. Disassembling the Canon PowerShot A200 Case, Disassembling the Canon PowerShot A200 Case: 1 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two screws at the bottom of the camera.
  2. Disassembling the Canon PowerShot A200 Case: 2 단계, 이미지 1/2 Disassembling the Canon PowerShot A200 Case: 2 단계, 이미지 2/2
    • Locate a screw and a rubber covering on the left side of the camera. Slide the rubber covering to expose a second screw.
    • Remove both screws with the Phillips #00 screwdriver.
  3. Disassembling the Canon PowerShot A200 Case: 3 단계, 이미지 1/2 Disassembling the Canon PowerShot A200 Case: 3 단계, 이미지 2/2
    • Open the battery compartment on the right side of the camera by pushing slightly in the direction of the arrow.
    • Be sure to remove the memory card.
    • Remove the two screws by the memory card slot using the Phillips #00 screwdriver.
  4. Disassembling the Canon PowerShot A200 Case: 4 단계, 이미지 1/2 Disassembling the Canon PowerShot A200 Case: 4 단계, 이미지 2/2
    • Pull the grey tab towards the back of the camera. Lift the black cover to expose the battery slots.
    • Remove the two visible screws with the Phillips #00 screwdriver.
    • During reassembly, the holes for these screws must align properly with the interior of the camera body. Then the black battery cover must lie flat and be held in place by the grey tab.
  5. Disassembling the Canon PowerShot A200 Case: 5 단계, 이미지 1/2 Disassembling the Canon PowerShot A200 Case: 5 단계, 이미지 2/2
    • Remove the screen battery located to the left of the screen.
  6. Disassembling the Canon PowerShot A200 Case: 6 단계, 이미지 1/2 Disassembling the Canon PowerShot A200 Case: 6 단계, 이미지 2/2
    • Gently pull the camera apart from the top.
    • Be careful. The two halves are still attached by two short ribbons at the bottom of the camera.
  7. Disassembling the Canon PowerShot A200 Case: 7 단계, 이미지 1/2 Disassembling the Canon PowerShot A200 Case: 7 단계, 이미지 2/2
    • Locate the black tabs on either side of the white ribbon.
    • Use the metal tweezers to gently move these tabs to the outside edges of the ribbon.
    • Gently pull the white ribbon out from its connection.
  8. Disassembling the Canon PowerShot A200 Case: 8 단계, 이미지 1/3 Disassembling the Canon PowerShot A200 Case: 8 단계, 이미지 2/3 Disassembling the Canon PowerShot A200 Case: 8 단계, 이미지 3/3
    • Locate the black tabs on either side of the orange ribbon.
    • Gently pull the orange ribbon out of its connection.
    • Your camera will now be in two separate pieces.
결론
Daniel Stone
회원 가입일: 01/28/11
101 평판
안내서 1개 작성함
Cal Poly, Team 7-37, Regan Winter 2011 Cal Poly, Team 7-37, Regan Winter 2011 회원
CPSU-REGAN-W11S7G37
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 655
