주요 콘텐츠로 건너뛰기
Disassembling the Ematic Genesis
필요한 것
  1. Disassembling the Ematic Genesis, Ematic Genesis Casing: 1 단계, 이미지 1/3 Disassembling the Ematic Genesis, Ematic Genesis Casing: 1 단계, 이미지 2/3 Disassembling the Ematic Genesis, Ematic Genesis Casing: 1 단계, 이미지 3/3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
  2. Disassembling the Ematic Genesis: 2 단계, 이미지 1/3 Disassembling the Ematic Genesis: 2 단계, 이미지 2/3 Disassembling the Ematic Genesis: 2 단계, 이미지 3/3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
  3. Disassembling the Ematic Genesis: 3 단계, 이미지 1/1
    • Remove back plate from screen plate and lay both down flat next to each other.
결론
Justin Rohrman
회원 가입일: 03/23/15
745 평판
안내서 6개 작성하였습니다
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 311
