주요 콘텐츠로 건너뛰기
Disassembling the Garmin eTrex Vista-H Outer Case
필요한 것
  1. Disassembling the Garmin eTrex Vista-H Outer Case, Removing Battery: 1 단계, 이미지 1/1
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Disassembling the Garmin eTrex Vista-H Outer Case: 2 단계, 이미지 1/1
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Disassembling the Garmin eTrex Vista-H Outer Case: 3 단계, 이미지 1/2 Disassembling the Garmin eTrex Vista-H Outer Case: 3 단계, 이미지 2/2
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: 4 단계, 이미지 1/2 Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: 4 단계, 이미지 2/2
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Disassembling the Garmin eTrex Vista-H Outer Case: 5 단계, 이미지 1/3 Disassembling the Garmin eTrex Vista-H Outer Case: 5 단계, 이미지 2/3 Disassembling the Garmin eTrex Vista-H Outer Case: 5 단계, 이미지 3/3
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Disassembling the Garmin eTrex Vista-H Outer Case: 6 단계, 이미지 1/1
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Disassembling the Garmin eTrex Vista-H Outer Case: 7 단계, 이미지 1/2 Disassembling the Garmin eTrex Vista-H Outer Case: 7 단계, 이미지 2/2
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Ryan Green
회원 가입일: 10/17/10
93 평판
안내서 1개 작성함
Cal Poly, Team 21-30, Regan Fall 2010 Cal Poly, Team 21-30, Regan Fall 2010 회원
CPSU-REGAN-F10S21G30
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 4,982
