주요 콘텐츠로 건너뛰기
Disassembling the Linksys E1200
필요한 것
  1. Disassembling the Linksys E1200, Cover and Circuit Board: 1 단계, 이미지 3개 중 1개 Disassembling the Linksys E1200, Cover and Circuit Board: 1 단계, 이미지 3개 중 2개 Disassembling the Linksys E1200, Cover and Circuit Board: 1 단계, 이미지 3개 중 3개
    • Opening the device will void your warranty.
    • Anti-slip pads cover three screws that hold the device together. Pry off the pads to access the screws.
    • Remove the three screws.
    • Save the pads for reassembly.
  2. Disassembling the Linksys E1200: 2 단계, 이미지 3개 중 1개 Disassembling the Linksys E1200: 2 단계, 이미지 3개 중 2개 Disassembling the Linksys E1200: 2 단계, 이미지 3개 중 3개
    • Once the three screws are removed, the device is ready for disassembly.
    • Push up on the rear flap while holding down on the rest of the body. This will open a small gap.
    • Insert the plastic opening tool in the gap and begin prying on the corner.
    • Continue to pry around the body of the case. Separate both sides of the case with this method.
  3. Disassembling the Linksys E1200: 3 단계, 이미지 2개 중 1개 Disassembling the Linksys E1200: 3 단계, 이미지 2개 중 2개
    • Once the sides are released, the front of the cover can be removed.
    • Use a plastic opening tool to separate the front of the cover from the body.
    • It is helpful to use a different plastic opening tool as a wedge on the sides to prevent them from snapping back together.
  4. Disassembling the Linksys E1200: 4 단계, 이미지 3개 중 1개 Disassembling the Linksys E1200: 4 단계, 이미지 3개 중 2개 Disassembling the Linksys E1200: 4 단계, 이미지 3개 중 3개
    • The cover can now be removed.
    • To repair anything on the circuit board, use the plastic opening tool to pull back on the two tabs holding it down.
    • Use caution when pulling on the tabs as they are stiff and easy to break.
    • Keep the tabs if they snap off. The tabs can be reattached with glue when reassembling the device.
  5. Disassembling the Linksys E1200: 5 단계, 이미지 3개 중 1개 Disassembling the Linksys E1200: 5 단계, 이미지 3개 중 2개 Disassembling the Linksys E1200: 5 단계, 이미지 3개 중 3개
    • If the antenna needs to be disconnected, desolder the connection and reattach it prior to reassembly.
    • If the ethernet ports, power port, or reset button are damaged, the large solder points allow you to replace them.
    • Many components on the board cannot be serviced. These components were attached by a machine and cannot be removed.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Tahisha Hicks
회원 가입일: 02/24/14
409 평판
안내서 4개를 작성함
Michigan Tech, Team 5-4, Lauer Spring 2014 Michigan Tech, Team 5-4, Lauer Spring 2014 회원
MTU-LAUER-S14S5G4
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 7,354
