주요 콘텐츠로 건너뛰기
Disassembling the Nintendo 64 (without special tools)
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Disassembling the Nintendo 64 (without special tools), Disassembling the Nintendo 64 (without special tools): 1 단계, 이미지 1/1
    • You will need a kitchen lighter and a plastic pen shell, and you will want to do this outdoors to allow the plastic the burn into the air instead of trapping it in a room. Heat the tip of the empty pen shell until it melts into a glob.
  2. Disassembling the Nintendo 64 (without special tools): 2 단계, 이미지 1/1
    • Stick the pen into one of the 6 holes on the bottom of the Nintendo 64. When it reaches the screw, press forcefully for about three seconds and then let go.
    • TIP: The circled hole has the smallest inner diameter, so if you mold your pen with this hole, you can remove the others without remolding if you are careful not to strip it.
  3. Disassembling the Nintendo 64 (without special tools): 3 단계, 이미지 1/1
    • Allow the pen to reform and solidify around the screw for 4 to 5 minutes. If done correctly, the pen will mold completely around the specialized screw and grip it so that it can be twisted out.
  4. Disassembling the Nintendo 64 (without special tools): 4 단계, 이미지 1/1
    • Grip the pen and, pushing down forcefully, begin to twist it loose (to the left) as if you were using an actual screwdriver. The screw should come out with the pen as shown in the picture if done flawlessly. If not, you can still manage to get the screw out without it molding completely.
  5. Disassembling the Nintendo 64 (without special tools): 5 단계, 이미지 1/1
    • Repeat the melting and re-solidifying process 5 more times for the rest of the screws, and the console will be ready to be opened up for repair.
  6. Disassembling the Nintendo 64 (without special tools): 6 단계, 이미지 1/1
    • Open the outer shell of the case if it is not already opened. For a how-to on that, go here.
  7. Disassembling the Nintendo 64 (without special tools): 7 단계, 이미지 1/1
    • Once the case is off, turn your attention to the silver plate covering the green motherboard underneath. Begin unscrewing the screws connecting the plate to the motherboard.
    • Also remove the two smaller screws on the expansion slot.
  8. Disassembling the Nintendo 64 (without special tools): 8 단계, 이미지 1/1
    • The motherboard is now free to be worked on.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Benjamin Donnelly
회원 가입일: 10/29/13
1,240 평판
안내서 4개 작성하였습니다
University of Maryland, Team 1-6, Shastany Fall 2013 University of Maryland, Team 1-6, Shastany Fall 2013 회원
UMD-SHASTANY-F13S1G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 18,041
