주요 콘텐츠로 건너뛰기
Disassembling the Nokia 6300
필요한 것
  1. Disassembling the Nokia 6300, Rear Cover: 1 단계, 이미지 1/1
    • Take off the back cover by pushing it down and sliding it backwards.
  2. Disassembling the Nokia 6300: 2 단계, 이미지 1/2 Disassembling the Nokia 6300: 2 단계, 이미지 2/2
    • Take out the battery, SIM card, and MicroSD card.
    • Unscrew the two T6 Torx screws.
  3. Disassembling the Nokia 6300: 3 단계, 이미지 1/1
    • Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
    • The first time you do this you may have to use some force but do it in a controlled way. If you break the plastic clips you'll need a new front cover.
  4. Disassembling the Nokia 6300: 4 단계, 이미지 1/1
    • You can take off the keypad now, this is sitting loose on top of the sensors.
    • Unscrew the four remaining T6 Torx screws.
    • The screws holding the motherboard in place are different from the two previous screws which held the rear cover in place.
  5. Disassembling the Nokia 6300: 5 단계, 이미지 1/1
    • The motherboard with it's screen are now loose, you can pop it right out.
    • If you've been using this phone for a while, there's probably some dust inside the back shell.
    • There's a lot of contacts exposed, so make sure not to damage those.
  6. Disassembling the Nokia 6300: 6 단계, 이미지 1/3 Disassembling the Nokia 6300: 6 단계, 이미지 2/3 Disassembling the Nokia 6300: 6 단계, 이미지 3/3
    • There's your phone!
결론
다른 20명이 해당 안내서를 완성하였습니다.
LucasJV
회원 가입일: 05/18/10
735 평판
안내서 3개 작성하였습니다
Verheij.co Verheij.co 회원
Business
1 회원
안내서 5개 작성하였습니다
댓글 한 개
in this where is bluetooth module plzz give me ans @ bhatia.abhi98@gmail.com
abhishek - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 31
전체 시간: 23,681
