주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling the Nokia 6300
필요한 것
  1. Disassembling the Nokia 6300, Rear Cover: 1 단계, 이미지 1개 중 1개
    • Take off the back cover by pushing it down and sliding it backwards.
  2. Disassembling the Nokia 6300: 2 단계, 이미지 2개 중 1개 Disassembling the Nokia 6300: 2 단계, 이미지 2개 중 2개
    • Take out the battery, SIM card, and MicroSD card.
    • Unscrew the two T6 Torx screws.
  3. Disassembling the Nokia 6300: 3 단계, 이미지 1개 중 1개
    • Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
    • The first time you do this you may have to use some force but do it in a controlled way. If you break the plastic clips you'll need a new front cover.
  4. Disassembling the Nokia 6300: 4 단계, 이미지 1개 중 1개
    • You can take off the keypad now, this is sitting loose on top of the sensors.
    • Unscrew the four remaining T6 Torx screws.
    • The screws holding the motherboard in place are different from the two previous screws which held the rear cover in place.
  5. Disassembling the Nokia 6300: 5 단계, 이미지 1개 중 1개
    • The motherboard with it's screen are now loose, you can pop it right out.
    • If you've been using this phone for a while, there's probably some dust inside the back shell.
    • There's a lot of contacts exposed, so make sure not to damage those.
  6. Disassembling the Nokia 6300: 6 단계, 이미지 3개 중 1개 Disassembling the Nokia 6300: 6 단계, 이미지 3개 중 2개 Disassembling the Nokia 6300: 6 단계, 이미지 3개 중 3개
    • There's your phone!
결론
다른 20명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
LucasJV
회원 가입일: 05/18/10
741 평판
안내서 3개를 작성함
1가이드 댓글
in this where is bluetooth module plzz give me ans @ bhatia.abhi98@gmail.com
abhishek - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 123
전체 시간: 25,242
