이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Take out the battery, SIM card, and MicroSD card.
Unscrew the two T6 Torx screws.
Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
You can take off the keypad now, this is sitting loose on top of the sensors.
Unscrew the four remaining T6 Torx screws.
The motherboard with it's screen are now loose, you can pop it right out.
If you've been using this phone for a while, there's probably some dust inside the back shell.
There's a lot of contacts exposed, so make sure not to damage those.
다른 20명이 해당 안내서를 완성하였습니다.
