이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Ensure that the hard disk has been removed. Carefully detach the bottom cover.
Remove the 4 screws to detach the battery.
Remove all of the sticky tape.
Carefully disconnect the small power connector by using a tool to push the connector out through the small gap in the middle of the connector.
This is the Samsung 7.4V 45Wh battery.
Ensure that the battery is removed before continuing.
Remove the processor fan.
There are 2 screws holding it in place. Loosen and remove them.
Remove the processor heat sink.
3 screws hold this part in place. Loosen and remove them.
다른 34명이 해당 안내서를 완성하였습니다.
댓글 30개
Hello,
Do you know where can i reset the Bios CMOS in that motherboard?
I think there are people who wants to know becose system upgrade is leading to bios ACPI Error.
Thanks for your help
No, I do not know where is a reset pin of BIOS.
Try to disconnect NVRAM battery.
Wait 15 minutes and reconnect again.
