주요 콘텐츠로 건너뛰기
Disassembly of Sony BDP-BX18 Blu-ray player
필요한 것
  1. Disassembly of Sony BDP-BX18 Blu-ray player, Blu-ray player: 1 단계, 이미지 1/1
    • Remove the face plate by depressing the small plastic tab
    • *NOTE: eject disk tray first before dis-assembly to gain access.
  2. Disassembly of Sony BDP-BX18 Blu-ray player: 2 단계, 이미지 1/1
    • Release front 4 tabs in order to slide main cover forward.
    • *NOTE: slide only a few mils forwards before next step.
  3. Disassembly of Sony BDP-BX18 Blu-ray player: 3 단계, 이미지 1/1
    • Release tabs on both left and right sides of unit while maintaining forward pressure to slide cover off.
    • *NOTE: The arrows depict where the tabs are located.
  4. Disassembly of Sony BDP-BX18 Blu-ray player: 4 단계, 이미지 1/1
    • After cover removal, you should now have access to the internal components.
    • We will begin removing the power supply. Compress the center clip and open plastic shield.
  5. Disassembly of Sony BDP-BX18 Blu-ray player: 5 단계, 이미지 1/1
    • Release clip to remove 6 pin power cable.
  6. Disassembly of Sony BDP-BX18 Blu-ray player: 6 단계, 이미지 1/1
    • Unscrew two mounting screw for power supply. Slide forward and pull out for removal.
  7. Disassembly of Sony BDP-BX18 Blu-ray player: 7 단계, 이미지 1/1
    • This should be your current progress thus far.
  8. Disassembly of Sony BDP-BX18 Blu-ray player: 8 단계, 이미지 1/1
    • Release tab to remove plastic power supply shield.
  9. Disassembly of Sony BDP-BX18 Blu-ray player: 9 단계, 이미지 1/2 Disassembly of Sony BDP-BX18 Blu-ray player: 9 단계, 이미지 2/2
    • Remove the three screws.
    • Now depress metal tab to fully remove heat sink clamp.
  10. Disassembly of Sony BDP-BX18 Blu-ray player: 10 단계, 이미지 1/2 Disassembly of Sony BDP-BX18 Blu-ray player: 10 단계, 이미지 2/2
    • Pull on indicated ribbon cable to begin removal of front display.
    • Now remove single screw to remove front display panel.
  11. Disassembly of Sony BDP-BX18 Blu-ray player: 11 단계, 이미지 1/1
    • This should be you current dis-assembly progress thus far.
  12. Disassembly of Sony BDP-BX18 Blu-ray player: 12 단계, 이미지 1/2 Disassembly of Sony BDP-BX18 Blu-ray player: 12 단계, 이미지 2/2
    • Next, remove all three ribbon cables attached to optical disc drive.
    • *NOTE: largest ribbon cable has small secure clamp, be sure to release it before pulling.
    • Now unscrew both mounting screw for optical disc drive for complete removal.
  13. Disassembly of Sony BDP-BX18 Blu-ray player: 13 단계, 이미지 1/1
    • To completely remove the main board, locate screws on back of unit. Unscrew these 2 screws and then slide main board out.
  14. Disassembly of Sony BDP-BX18 Blu-ray player: 14 단계, 이미지 1/1
    • You should now be completely dis-assembled. For further dis-assembly of the optical disc drive, continue to step 15.
  15. Disassembly of Sony BDP-BX18 Blu-ray player: 15 단계, 이미지 1/3 Disassembly of Sony BDP-BX18 Blu-ray player: 15 단계, 이미지 2/3 Disassembly of Sony BDP-BX18 Blu-ray player: 15 단계, 이미지 3/3
    • First remove metal shroud exposing tabs.
    • Peel back security tape and release all 4 tabs (2 on each side) for removal of top cover.
    • Now the internal components of the optical disc drive are now exposed.
결론
다른 6명이 해당 안내서를 완성하였습니다.
TEAM 7
회원 가입일: 04/01/13
335 평판
안내서 1개 작성함
댓글 7개
Hi! I have just a quick question! The front display panel of my Sony Blu Ray player had broken! The small board with the USB mounted onto it, remote sensor and buttons! What is the name of this board? I was looking to order a replacement
earlovann - 답글
Nice info. Need to know how to get replacement bluray player. Any ideas? Do not want to buy new TV yet.
Keith - 답글
now I know I'm missing lots of parts...lol
Tina Marie - 답글
Thanks! the hardest part was getting the tray out.
Blake Horsfall - 답글
Cannon proceed past 3, I dont understand how you are supposed to release the tabs and press forward, I only have two hands. The tabs click back in place immediately and I don't have any place to get a grip of to remove the plate
Sira Q - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 53
전체 시간: 17,004
