주요 콘텐츠로 건너뛰기
Disassembly of the Dreame L10s Ultra base station
필요한 것
  1. Disassembly of the Dreame L10s Ultra base station, Remove the cover: 1 단계, 이미지 2개 중 1개 Disassembly of the Dreame L10s Ultra base station, Remove the cover: 1 단계, 이미지 2개 중 2개
    • Remove the four screws from the cover. Use a Phillips screwdriver to loosen them. Be careful not to lose the screws – they are small and can easily disappear!
    • Then fold in the hinges of the cover
  2. Disassembly of the Dreame L10s Ultra base station, Remove the top cover: 2 단계, 이미지 3개 중 1개 Disassembly of the Dreame L10s Ultra base station, Remove the top cover: 2 단계, 이미지 3개 중 2개 Disassembly of the Dreame L10s Ultra base station, Remove the top cover: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Jimmy
    $7.95
    • The top cover is held on with clips.
    • Carefully move the Jimmy underneath. Place the tool on an edge and slowly work your way around the casing to avoid damage.
    • You have to be especially careful around the area of the three buttons (see picture 3).
  3. Disassembly of the Dreame L10s Ultra base station, Remove the upper screws.: 3 단계, 이미지 1개 중 1개
    • Take out the two marked screws using a PH2 screwdriver.
  4. Disassembly of the Dreame L10s Ultra base station, Remove the cover from the bottom: 4 단계, 이미지 2개 중 1개 Disassembly of the Dreame L10s Ultra base station, Remove the cover from the bottom: 4 단계, 이미지 2개 중 2개
    • Remove the seven screws on the bottom of the base station with a PH2 screwdriver
    • Detach the plate on the underside. To do this, take care of the clips in Fig. 2 above the label with the type designation.
  5. Disassembly of the Dreame L10s Ultra base station, Remove the screws at the bottom: 5 단계, 이미지 1개 중 1개
    • Remove the two marked screws with a PH2 screwdriver.
  6. Disassembly of the Dreame L10s Ultra base station, Remove the screws at the back: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Now you need to remove the cover for the seven marked screws. You can do this either with tweezers or, if you want to be sure that nothing gets damaged, with a Halberd Spudger.
    • Remove the seven marked screws with a PH2 screwdriver.
  7. Disassembly of the Dreame L10s Ultra base station, Remove the cover: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iFixit Opening Picks (Set of 6)
    • On both sides of the cover, the plastic hooks on my model are located at approximately the following positions, measured from the bottom:
    • 125 mm
    • 215 mm
    • 280 mm
    • 395 mm
    • 455 mm
    • The hooks are each about 10 mm wide and can be relatively easily removed with the help of the jimmy and prevented from snapping back in with opening picks.
    • The process is repeated on both sides.
  8. Disassembly of the Dreame L10s Ultra base station, Maintenance, repair, cleaning: 8 단계, 이미지 1개 중 1개
    • Now the desired maintenance/repairs can be carried out.
    • In any case, it makes sense to at least remove the dust and dirt while the device is open. You can do this with compressed air or a brush so that you do not damage any sensitive parts.
결론
To reassemble your device, follow the steps in reverse order. When reassembling, be careful not to overtighten the screws, which could damage the case.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Sebastian
회원 가입일: 08/16/24
256 평판
안내서 1개를 작성함
댓글 한 개
Has anybody found reliable sources for repair parts? The contacts for charging the robot have arc buildup. I tried contact cleaner and am planning on filing down, but would rather just replace.
Richard Malott - 답글
댓글 쓰기
조회 통계:
지난 24시간: 25
지난 7일: 126
지난 30일: 542
전체 시간: 3,072
