주요 콘텐츠로 건너뛰기
Disconnecting (Top) Nintendo DSi Motherboard cables
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. 주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Disconnecting (Top) Nintendo DSi Motherboard cables, Battery: 1 단계, 이미지 1/1
    • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
  2. Disconnecting (Top) Nintendo DSi Motherboard cables: 2 단계, 이미지 1/1
    • L Button.
    • Top of the battery pack.
    • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
  3. Disconnecting (Top) Nintendo DSi Motherboard cables, Lower Case Assembly: 3 단계, 이미지 1/2 Disconnecting (Top) Nintendo DSi Motherboard cables, Lower Case Assembly: 3 단계, 이미지 2/2
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
  4. Disconnecting (Top) Nintendo DSi Motherboard cables: 4 단계, 이미지 1/1
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Disconnecting (Top) Nintendo DSi Motherboard cables: 5 단계, 이미지 1/3 Disconnecting (Top) Nintendo DSi Motherboard cables: 5 단계, 이미지 2/3 Disconnecting (Top) Nintendo DSi Motherboard cables: 5 단계, 이미지 3/3
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Disconnecting (Top) Nintendo DSi Motherboard cables: 6 단계, 이미지 1/2 Disconnecting (Top) Nintendo DSi Motherboard cables: 6 단계, 이미지 2/2
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Disconnecting (Top) Nintendo DSi Motherboard cables, Wi-Fi Board: 7 단계, 이미지 1/1
    • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
  8. Disconnecting (Top) Nintendo DSi Motherboard cables: 8 단계, 이미지 1/1
    • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  9. 주의: 9-10 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    Disconnecting (Top) Nintendo DSi Motherboard cables, Disconnecting Nintendo DSi Battery Board: 9 단계, 이미지 1/1
    • Flip up the black latch and disconnect the D-Pad/Power Button ribbon cable.
  10. Disconnecting (Top) Nintendo DSi Motherboard cables: 10 단계, 이미지 1/3 Disconnecting (Top) Nintendo DSi Motherboard cables: 10 단계, 이미지 2/3 Disconnecting (Top) Nintendo DSi Motherboard cables: 10 단계, 이미지 3/3
    • The power connector (with red and black wires) is difficult to remove without damaging it, unless you take a moment and understand how it works. Look at all of the photos for this step before continuing.
    • The connector is two pieces -- a white "male" piece (connected to the wires), and a beige "female" part (soldered to the main board).
    • There is a small "notch" in the female part, to give you a place to insert a small flat-head screwdriver. Put the corner of your screwdriver in there, and twist it gently to push the white part up (away from the main board). Do not try to pull it to the right (towards the battery board).
    • If it does not lift easily, try again with a smaller screwdriver. You might be pulling the female connector off the board, which will be difficult to repair.
  11. Disconnecting (Top) Nintendo DSi Motherboard cables, Disconnecting (Top) Nintendo DSi Motherboard cables: 11 단계, 이미지 1/2 Disconnecting (Top) Nintendo DSi Motherboard cables, Disconnecting (Top) Nintendo DSi Motherboard cables: 11 단계, 이미지 2/2
    • If you have not already done so, disconnect the two bottom-LCD ribbon cables from the main board by prying up the black latches and pulling the cable out to the side.
    • The ribbon cable (marked in blue) for the touch screen is particularly thin and fragile; be careful to avoid bending it more than necessary.
    • Flip up the latch and remove the touch screen cable.
    • Flip up the latch and remove the top-screen ribbon cable.
    • Pry up on the orange cable to disconnect it from the main board, much like the antenna cable on the Wi-Fi module.
    • Do not pull on the orange cable that connects to the bottom of the motherboard.
결론
bushing
회원 가입일: 04/23/10
10,250 평판
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 9
전체 시간: 1,778
