메인 콘텐츠로 스킵하기
소개
A step-by-step guide to disconnecting the wiring attached to the screen of the Garmin Nuvi 680.
  1. Flip open the antenna on the back of the device.
    • Flip open the antenna on the back of the device.
    • Remove the two screws on the antenna cover using a T5 Torx screwdriver.
    • These screws are 4.42 mm long.
  2. Remove the antenna cover.
    • Remove the antenna cover.
  3. The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. Insert the pointed end of a spudger into the leftmost slit of the antenna case. Push the spudger to the right.
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  6. Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  7. Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables. Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  8. Use a spudger to disconnect the yellow antenna wire from the ZIF connector on the back of the motherboard. Remove the antenna.
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector on the back of the motherboard.
    • Remove the antenna.
  9. Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
    • Gently pull the ribbon cables out of their connectors. They should slide out easily.
    • Do not separate the two halves of the device yet or the on/off cable may be severed.
  10. Gently pull the cable for the on/off button straight up to remove it. The two halves of the device may now be separated.
    • Gently pull the cable for the on/off button straight up to remove it.
    • The two halves of the device may now be separated.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Allen Pasch
회원 가입일: 2011년 01월 20일
255 평판
안내서 1개 작성함
Cal Poly, Team 5-22, Amido Winter 2011 Cal Poly, Team 5-22, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G22
5 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 1
전체 시간: 2,323
