소개
This guide is for the replacement of compontents like: the memory, hard drive, and heat sink.
I replace the thermal paste between the CPU and heat sink or "fan cooler". It includes the cleaning of the internal components of the laptop. This prevents overheating.
필요한 것
추천 문서
Place the laptop facing down with the battery upwards in your work area.
Remove the battery sliding the safety latch to the left.
Remove the WWAN card screw.
Push upwards the DVD unit safety latch.
The DVD unit should slide out. Remove it.
Using a #000 Phillips screwdriver, remove the 4 screws that close the fan housing.
With a small brush or a toothbrush, remove the dust. BE CAREFUL: the fan blades are VERY fragile, do not apply too much force with your fingers.
Close and screw the cooling fan housing. You can see the fan requires 5 volts, 1.55 watts and a 2 pin cable in order to work.
To reassemble your device, follow the instructions from the last to first step.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
