필요한 것
Remove the green board with the controls first.
DON'T USE FORCE, it should get lose easily. Don't bend the cables too much.
Remove the cable from the control board
Lift the display off, don't bed the cable too much.
Open the connector of the cable carefully. Don't scratch the board and don't use too much force. Ideally, use a plastic spudger of the ifixit-kit
The display got removed, not just fit the new display in reveresed order.
Follow the steps in reverse order to reassemble.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
