소개
This describes a diagnostic test for Acura technicians investigating ... well, issues with the climate control, or other sensors. Value to the owner/operator = minimal. But it's fun to try out.
Let's have at it.
Insert the key in the ignition.
On the heating/cooling control, press and hold the AUTO and DUAL buttons.
Turn the ignition key to Start (III) to start the vehicle normally. (The key returns to the ON (II) position after starting.)
Sensor values start displaying on the climate control display.
Cycle through the displayed values with the REAR DEFROSTER button. The code for display displays in the left (Driver's temp) segment, alternating the code number and the value.
1. In-car temperature in Celsius.
2. Ambient temperature in Celsius.
3. Solar radiation sensor: Dark=00, flashlight=04, cloudy=10, sunny=65.
4. Engine coolant temperature.
5. Evaporator outlet temp in Celsius.
6. Driver's air mix opening (% of opening).
More information on diagnostic tests and self-repair can be found here on iFixit, and tsx.acurazine.com.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Hi David, by any chance, do you have any guides/tips for troubleshooting a blank display that won't turn on for a navigation system on a Acura 2005 TSX? Thanks!
