주요 콘텐츠로 건너뛰기
Display all the vehicle temperature sensors
  1. Display all the vehicle temperature sensors, Display all the vehicle temperature sensors: 1 단계, 이미지 1/3 Display all the vehicle temperature sensors, Display all the vehicle temperature sensors: 1 단계, 이미지 2/3 Display all the vehicle temperature sensors, Display all the vehicle temperature sensors: 1 단계, 이미지 3/3
    • Insert the key in the ignition.
    • On the heating/cooling control, press and hold the AUTO and DUAL buttons.
    • Turn the ignition key to Start (III) to start the vehicle normally. (The key returns to the ON (II) position after starting.)
    • Sensor values start displaying on the climate control display.
  2. Display all the vehicle temperature sensors: 2 단계, 이미지 1/2 Display all the vehicle temperature sensors: 2 단계, 이미지 2/2
    • Cycle through the displayed values with the REAR DEFROSTER button. The code for display displays in the left (Driver's temp) segment, alternating the code number and the value.
    • 1. In-car temperature in Celsius.
    • 2. Ambient temperature in Celsius.
    • 3. Solar radiation sensor: Dark=00, flashlight=04, cloudy=10, sunny=65.
    • 4. Engine coolant temperature.
    • 5. Evaporator outlet temp in Celsius.
    • 6. Driver's air mix opening (% of opening).
    • 7. Passenger's air mix opening.
    • 8. Vehicle speed in Km/h.*
    • *2004-2005 model year. Later years shows 00 for 0-9 Km/h, 01 for 10-19 Km/h, etc.
    • 9. Vent air out temperature.
결론
More information on diagnostic tests and self-repair can be found here on iFixit, and tsx.acurazine.com.
다른 3명이 해당 안내서를 완성하였습니다.
David Spalding
회원 가입일: 11/12/15
6,470 평판
안내서 12개 작성하였습니다
댓글 한 개
Hi David, by any chance, do you have any guides/tips for troubleshooting a blank display that won't turn on for a navigation system on a Acura 2005 TSX? Thanks!
Mike Cardona - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,004
