이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert the key in the ignition.
On the heating/cooling control, press and hold the AUTO and DUAL buttons.
Turn the ignition key to Start (III) to start the vehicle normally. (The key returns to the ON (II) position after starting.)
Sensor values start displaying on the climate control display.
Cycle through the displayed values with the REAR DEFROSTER button. The code for display displays in the left (Driver's temp) segment, alternating the code number and the value.
1. In-car temperature in Celsius.
2. Ambient temperature in Celsius.
3. Solar radiation sensor: Dark=00, flashlight=04, cloudy=10, sunny=65.
4. Engine coolant temperature.
5. Evaporator outlet temp in Celsius.
6. Driver's air mix opening (% of opening).
7. Passenger's air mix opening.
8. Vehicle speed in Km/h.*
9. Vent air out temperature.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Hi David, by any chance, do you have any guides/tips for troubleshooting a blank display that won't turn on for a navigation system on a Acura 2005 TSX? Thanks!
