소개
This guide will show how to fix a stuffed animal squeak toy for a dog. These skills may work on any stuffed toy and can be very useful. Prior knowledge on sewing is recommended. A clean work space and clean, clear lighting is, also, recommended.
If the dog toy doesn’t squeak when pressure is applied to it, then it’s most likely that the squeaker portion of the dog toy is punctured. This will require replacement.
This guide will show you how to cut open the plush toy, replace the squeaker, and sew it back to it’s original state.
필요한 것
Using scissors, cut a hole about 2 inches to expose the toys stuffing and punctured squeaker. Make the incision on the back of the toy.
다른 한 분이 해당 안내서를 완성하였습니다.
