주요 콘텐츠로 건너뛰기
Domestic waterworks water bladder replacement
필요한 것
  1. Domestic waterworks water bladder replacement, Preliminary work: 1 단계, 이미지 1/3 Domestic waterworks water bladder replacement, Preliminary work: 1 단계, 이미지 2/3 Domestic waterworks water bladder replacement, Preliminary work: 1 단계, 이미지 3/3
    • Domestic waterworks make off, then close the shut-off valve from the water inlet. Then Depressurize the waterworks by the water from a tap.
  2. Domestic waterworks water bladder replacement, Open the boiler: 2 단계, 이미지 1/3 Domestic waterworks water bladder replacement, Open the boiler: 2 단계, 이미지 2/3 Domestic waterworks water bladder replacement, Open the boiler: 2 단계, 이미지 3/3
    • Loosen the screws with a 13 mm ring spanner, caution it runs out the water. Best to make a bucket to catch the water including. Then remove the cover. You can see the old bag. This can now be removed. The water bag is very dirty, therefore it is recommended to dress gloves
  3. Domestic waterworks water bladder replacement, Swap water bubble: 3 단계, 이미지 1/3 Domestic waterworks water bladder replacement, Swap water bubble: 3 단계, 이미지 2/3 Domestic waterworks water bladder replacement, Swap water bubble: 3 단계, 이미지 3/3
    • Remove the water bag. Now is still the remaining water from the leaky water bag in the boiler. With a hose through the rest of the water suction vacuum.
  4. Domestic waterworks water bladder replacement, Clean the boiler: 4 단계, 이미지 1/2 Domestic waterworks water bladder replacement, Clean the boiler: 4 단계, 이미지 2/2
    • The boiler then clean with old rags, since this has quite a rust deposits.
  5. Domestic waterworks water bladder replacement, Insert new water bubble: 5 단계, 이미지 1/3 Domestic waterworks water bladder replacement, Insert new water bubble: 5 단계, 이미지 2/3 Domestic waterworks water bladder replacement, Insert new water bubble: 5 단계, 이미지 3/3
    • Install the new water bag and then screw the lid. The screws should be not to tight. Please make sure that the water bag is properly seated. Usually this is more curved on a page, this page comes down.
  6. Domestic waterworks water bladder replacement, connection work: 6 단계, 이미지 1/2 Domestic waterworks water bladder replacement, connection work: 6 단계, 이미지 2/2
    • With a compressor or even foot pump produce about 1.5 bar pressure in the boiler. There should be no water in it. Then re-open the supply and take the House water system in operation. Possible must be drawn on a $!^&* to fill the pump a little water.
결론
The water system should work now correctly.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Wolfgang
회원 가입일: 01/20/17
677 평판
안내서 3개 작성하였습니다
댓글 3개
Ich habe noch eine Frage.
Ist das Wasser in der Blase oder im Kessel ? Und wo ist der Druck 1,5 Bar ?
e.stolz48 - 답글
Das Wasser ist natürlich in der Blase, Der Druck von 1,5 bar ist im Kessel , Den muss man mit einem Kompressor einstellen, jedoch darf zu diesem Zeitpunkt kein Wasser in der Blase sein. Also kurz nach dem Einbau. Wenn dann die Blase gefüllt wird und das Wasserwerk angeht wird ja der Druck in der Blase gemessen. Wenn jetzt kein Vordruck im Kessel da wäre würde das Hauswasserwerk ziemlich schnell ausschalten.
Wolfgang - 답글
Hallo zusammen, ich habe bei einem Güde Inox 100/24 genau nach deinen Angaben gearbeitet. Leider wird der Deckel vorne nicht mehr dicht und es tritt Wasser aus.
hast du einen Tip warum?
marc_wiesner@gmx.de - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 22
30일 전: 135
전체 시간: 7,168
