This guide will instruct users how to replace a door frame's damaged strike plate. This will allow for the door's lock to catch onto the strike plate.
A strike plate might need to be replaced because it is too damaged to properly work. If the door's lock is not catching onto the strike plate and firmly staying in place, the strike plate may need to be replaced.
Replace the damaged strike plate with a new strike plate.
The holes of the new strike plate should align with the holes of the damaged strike plate. If they do not, new holes on the door frame would need to be drilled.
