주요 콘텐츠로 건너뛰기
Door Hinge Replacement
필요한 것
  1. Door Hinge Replacement, Hinge: 1 단계, 이미지 1/2 Door Hinge Replacement, Hinge: 1 단계, 이미지 2/2
    • Take measurements of the door hinge using a tape measure and use the measurements to find a replacement door hinge.
  2. Door Hinge Replacement: 2 단계, 이미지 1/2 Door Hinge Replacement: 2 단계, 이미지 2/2
    • Use two sturdy pieces of wood or cardboard that can keep the door in place and put them underneath the door.
    • Make sure that the door isn’t slanted or tilted to make it easier to replace the new door hinge.
  3. Door Hinge Replacement: 3 단계, 이미지 1/2 Door Hinge Replacement: 3 단계, 이미지 2/2
    • Remove the three screws from the hinge that are connected to the door by using a Phillips 1 screwdriver.
    • Remove the three screws from the hinge that are connected to the door frame using a Phillips #1 screwdriver.
  4. Door Hinge Replacement: 4 단계, 이미지 1/2 Door Hinge Replacement: 4 단계, 이미지 2/2
    • Repeat Step 3 with the bottom hinge on the door.
  5. Door Hinge Replacement: 5 단계, 이미지 1/2 Door Hinge Replacement: 5 단계, 이미지 2/2
    • Rub sandpaper on the areas where the new hinges will be.
    • This makes sure that splinters or any wood debris from both the frame and the door will be removed.
  6. Door Hinge Replacement: 6 단계, 이미지 1/2 Door Hinge Replacement: 6 단계, 이미지 2/2
    • When replacing your new door hinge, make sure that the hinge that is facing towards you can be fully closed
  7. Door Hinge Replacement: 7 단계, 이미지 1/3 Door Hinge Replacement: 7 단계, 이미지 2/3 Door Hinge Replacement: 7 단계, 이미지 3/3
    • Align the new door hinge with the screw holes in the frame and screw in the new door hinge in the frame.
    • Repeat this with the bottom area of the door.
  8. Door Hinge Replacement: 8 단계, 이미지 1/3 Door Hinge Replacement: 8 단계, 이미지 2/3 Door Hinge Replacement: 8 단계, 이미지 3/3
    • Align the new door hinge with the screw holes in the door and screw in the new door hinge.
  9. Door Hinge Replacement: 9 단계, 이미지 1/2 Door Hinge Replacement: 9 단계, 이미지 2/2
    • Spray a small amount of WD-40 at the back top and bottom hinge and wipe it down with an old rag.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Zeniff Aviles
회원 가입일: 01/19/21
234 평판
안내서 1개 작성함
York University, Team S1-G31, Woodhouse Winter 2021 York University, Team S1-G31, Woodhouse Winter 2021 회원
YORK-WOODHOUSE-W21S1G31
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 27
전체 시간: 662
