주요 콘텐츠로 건너뛰기
Door Stop Replacement
필요한 것
  1. Door Stop Replacement, Door Stop: 1 단계, 이미지 1/3 Door Stop Replacement, Door Stop: 1 단계, 이미지 2/3 Door Stop Replacement, Door Stop: 1 단계, 이미지 3/3
    • Twist the anchor fitting of the old door stop in counter clockwise direction.
    • Remove the anchor fitting from the mount.
    • Anchor fitting: is a part of the door stop circled in red.
  2. Door Stop Replacement: 2 단계, 이미지 1/3 Door Stop Replacement: 2 단계, 이미지 2/3 Door Stop Replacement: 2 단계, 이미지 3/3
    • Use a drill (or a screwdriver) to remove the two screws from the mount base.
    • After you remove the mount base, use the hammer to reposition these two screws.
  3. Door Stop Replacement: 3 단계, 이미지 1/2 Door Stop Replacement: 3 단계, 이미지 2/2
    • Use a screwdriver to remove the mount base out of the new anchor fitting by spinning the screwdriver counter-clockwise.
  4. Door Stop Replacement: 4 단계, 이미지 1/3 Door Stop Replacement: 4 단계, 이미지 2/3 Door Stop Replacement: 4 단계, 이미지 3/3
    • Using a screwdriver or a drill, attach the new mount base to the wall with the two screws.
  5. Door Stop Replacement: 5 단계, 이미지 1/3 Door Stop Replacement: 5 단계, 이미지 2/3 Door Stop Replacement: 5 단계, 이미지 3/3
    • Attach the anchor fitting into the mount base by rotating it clockwise.
  6. Door Stop Replacement: 6 단계, 이미지 1/2 Door Stop Replacement: 6 단계, 이미지 2/2
    • Remove the old door fitting by rotating it counter-clockwise.
  7. Door Stop Replacement: 7 단계, 이미지 1/3 Door Stop Replacement: 7 단계, 이미지 2/3 Door Stop Replacement: 7 단계, 이미지 3/3
    • Use the drill to remove the two screws out of the threaded insert.
    • Clean the screws holes (if necessary) before putting a new screw in.
  8. Door Stop Replacement: 8 단계, 이미지 1/3 Door Stop Replacement: 8 단계, 이미지 2/3 Door Stop Replacement: 8 단계, 이미지 3/3
    • Insert a screwdriver into the bottom hole of the threaded insert and rotate it counter-clockwise to remove the threaded insert.
  9. Door Stop Replacement: 9 단계, 이미지 1/2 Door Stop Replacement: 9 단계, 이미지 2/2
    • Place the threaded insert onto the door.
    • Using a screwdriver or a drill, attach the threaded insert to the door with two screws.
  10. Door Stop Replacement: 10 단계, 이미지 1/3 Door Stop Replacement: 10 단계, 이미지 2/3 Door Stop Replacement: 10 단계, 이미지 3/3
    • Assemble the rest of the door stop in the following order:
    • Spring.
    • Rectangular compartment.
    • Door stop button.
    • Outer shell.
    • Place the door stopper onto the threaded insert and and attach it by rotating it clockwise.
결론
Khoa Bui
회원 가입일: 09/20/20
198 평판
안내서 1개 작성함
York University, Team S1-G111, Woodhouse Fall 2020 York University, Team S1-G111, Woodhouse Fall 2020 회원
YORK-WOODHOUSE-F20S1G111
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 25
30일 전: 95
전체 시간: 3,073
