주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Doorknob Privacy Pin Replacement
필요한 것
  1. Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: 1 단계, 이미지 3개 중 1개 Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: 1 단계, 이미지 3개 중 2개 Doorknob Privacy Pin Replacement, Doorknob Privacy Pin: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the two screws holding the interior and exterior doorknob halves together.
  2. Doorknob Privacy Pin Replacement: 2 단계, 이미지 2개 중 1개 Doorknob Privacy Pin Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully pull the doorknob halves apart.
    • The spindle and the latch mechanism should now be accessible.
  3. Doorknob Privacy Pin Replacement: 3 단계, 이미지 3개 중 1개 Doorknob Privacy Pin Replacement: 3 단계, 이미지 3개 중 2개 Doorknob Privacy Pin Replacement: 3 단계, 이미지 3개 중 3개
    • Use the Phillips #1 screwdriver to remove the privacy pin.
    • It is a small, threaded pin that screws into a hole on the latch mechanism itself or on the interior doorknob assembly.
  4. Doorknob Privacy Pin Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the old/ damaged privacy pin.
  5. Doorknob Privacy Pin Replacement: 5 단계, 이미지 3개 중 1개 Doorknob Privacy Pin Replacement: 5 단계, 이미지 3개 중 2개 Doorknob Privacy Pin Replacement: 5 단계, 이미지 3개 중 3개
    • Screw the new privacy pin into the corresponding hole.
    • Ensure it's securely tightened but don't overtighten, as this could strip the threads.
  6. Doorknob Privacy Pin Replacement: 6 단계, 이미지 3개 중 1개 Doorknob Privacy Pin Replacement: 6 단계, 이미지 3개 중 2개 Doorknob Privacy Pin Replacement: 6 단계, 이미지 3개 중 3개
    • Align the spindle with the latch mechanism, then bring the two doorknob halves back together.
    • Make sure all parts are properly seated.
  7. Doorknob Privacy Pin Replacement: 7 단계, 이미지 3개 중 1개 Doorknob Privacy Pin Replacement: 7 단계, 이미지 3개 중 2개 Doorknob Privacy Pin Replacement: 7 단계, 이미지 3개 중 3개
    • Securely fasten the two screws with the Phillips #1 screwdriver.
    • Snap or twist the decorative covers back into place (If applicable).
    • Test the privacy pin several times to ensure it engages and disengages smoothly.
결론
작성자
1다른 기여자 명과 함께
Elias Moseri
회원 가입일: 06/15/25
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 64
전체 시간: 341
