소개
A guide on how to replace the battery inside of a smartphone Doov v15.
Before
Make sure you have a replacement battery compatible with the Doov v15.
Work in a clean, well-lit area.
Use appropriate tools like a opening tool, and Jimmy.
Ensure you have the necessary safety gear to protect your eyes and hands.
Back up your data and power off the phone before you start. For additional help please use the step by step guide.
필요한 것
Use the Jimmy to crack open the phone's back cover. Slide it under an edge of the phones back cover and carefully loosen the edge. The casing should pop open slightly.
다른 2명이 해당 안내서를 완성하였습니다.
