주요 콘텐츠로 건너뛰기
Doov v15 Sim Card Replacement
필요한 것
  1. Doov v15 Sim Card Replacement, Sim Card: 1 단계, 이미지 1개 중 1개
    • Use the Jimmy to crack open the phone's back cover. Slide it under an edge of the phones back cover and carefully loosen the edge. The casing should pop open slightly.
  2. Doov v15 Sim Card Replacement: 2 단계, 이미지 2개 중 1개 Doov v15 Sim Card Replacement: 2 단계, 이미지 2개 중 2개
    • Use an Ifixit opening tool and slide it around the phones back cover. The Sim Card will be visible above the battery to the right.
  3. Doov v15 Sim Card Replacement: 3 단계, 이미지 2개 중 1개 Doov v15 Sim Card Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the battery: Once the back casing is removed, the battery will be visible. Use the ifixit opening tool to remove the battery. Place the ifixit opening tool at the top of the battery and pull it back, or simply use your hand to remove it.
  4. Doov v15 Sim Card Replacement: 4 단계, 이미지 2개 중 1개 Doov v15 Sim Card Replacement: 4 단계, 이미지 2개 중 2개
    • Use the Ifixit opening tool and place it in the hole above the SIM card slot and push it downwards, so the SIM card slides downward. Place the iFixit opening tool on the now more visible SIM card and slide it down for an easy removal.
  5. Doov v15 Sim Card Replacement: 5 단계, 이미지 2개 중 1개 Doov v15 Sim Card Replacement: 5 단계, 이미지 2개 중 2개
    • Place the new SIM card in the slot by sliding it back in the slot, as shown in the figure (facing the sim number and code upward.)
결론
작성자
2다른 기여자 명과 함께
Imani Williams
회원 가입일: 09/08/23
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 191
