주요 콘텐츠로 건너뛰기
Dopo Double Power 7 Battery Replacement
필요한 것
  1. Dopo Double Power 7 Battery Replacement, Rear Panel: 1 단계, 이미지 1/1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Battery Replacement: 2 단계, 이미지 1/1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Battery Replacement: 3 단계, 이미지 1/1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Battery Replacement: 4 단계, 이미지 1/1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Cut only the red and black wires attaching the battery to the motherboard.
    • Be sure to remove any remaining wire attached to the motherboard.
  6. Dopo Double Power 7 Battery Replacement: 6 단계, 이미지 1/1
    • Using a metal spudger, carefully pry the battery away from the digitizer.
    • Be careful to not damage the battery. This could result in injury.
  7. Dopo Double Power 7 Battery Replacement: 7 단계, 이미지 1/1
    • Using wire strippers, strip the ends of the red and black wires connected to the the new battery back about a 1/8".
    • Twist the strands of the spliced wire together.
    • Using a soldering iron, apply heat to one bare wire connections you have just made.
    • When the connection is hot enough melt solder on the opposite side of the wire to the iron as shown in the image. Do not melt to much solder.
    • Once connection is made wait for it to cool off and gently pull each side of the wire to test durability.
    • Repeat this process with the other wire.
    • If you do not have access to a soldering iron, leave the old battery wires attached to the motherboard and simply splice the new battery's wires to them.
    • This video provides basic instructions for splicing wires using crimping and heat shrink technique.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
mike pelosi
회원 가입일: 10/30/15
682 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015 회원
UMASSD-MILES-F15S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 1,016
