이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
The rear panel is secured to the front case and can simply be pried apart without damage.
Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
Use the flat end of a spudger to disconnect the front-facing camera cable from its socket on the motherboard.
Simply, pull back the tape and remove the camera.
Remove the four screws holding the motherboard inplace.
Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
The cables can be disconnected by lifting up on the black section of the socket.
Once the lever is lifted, pull out the cable by gently tugging on it.
Using a metal spudger, carefully pry the battery away from the digitizer.
The back of the digitizer is attached along the edge by 12 plastic clips.
Solder the new digitizer to the soldering point shown within the image.
Using wire strippers, strip the end of the gray wire connected to the new digitizer about a 1/8".
Solder the gray wire to the soldering point on the motherboard as shown within the image.
다른 2명이 해당 안내서를 완성하였습니다.
