이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
The rear panel is secured to the front case and can simply be pried apart without damage.
Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
The cables can be disconnected by lifting up on the black section of the socket, as shown by the arrow.
Using a Phillips Head Screwdriver size 0, remove the four screws attaching the motherboard.
Using wire cutters, cut the red, black, and grays wires.
The motherboard can now be removed
다른 한 분이 해당 안내서를 완성하였습니다.
