주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Purchasing a new or used speaker will be necessary if yours is broken. Since the Dopo Double Power 7 is not a very expensive or popular device, finding just the speaker for sale may be difficult. We suggest purchasing a used one with a functional speaker.
부품
지정된 부품이 없습니다.
  1. The rear panel is secured to the front case and can simply be pried apart without damage.
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. The rear panel should come completely off.
    • The rear panel should come completely off.
  5. Using wire cutters, cut the red and black wires connected to the speaker.
    • Using wire cutters, cut the red and black wires connected to the speaker.
    • The speaker is magnetized and not permanently attached.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
mike pelosi
회원 가입일: 2015년 10월 30일
682 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 1-2, Miles Fall 2015 UMass Dartmouth, Team 1-2, Miles Fall 2015 회원
UMASSD-MILES-F15S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 137
