주요 콘텐츠로 건너뛰기
Dragon Touch M10X Camera Replacement
필요한 것
  1. Dragon Touch M10X Camera Replacement, Camera: 1 단계, 이미지 1/2 Dragon Touch M10X Camera Replacement, Camera: 1 단계, 이미지 2/2
    • Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
  2. Dragon Touch M10X Camera Replacement: 2 단계, 이미지 1/1
    • Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
    • Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
  3. Dragon Touch M10X Camera Replacement: 3 단계, 이미지 1/2 Dragon Touch M10X Camera Replacement: 3 단계, 이미지 2/2
    • Using your hands and the separating tool, remove the back cover from the device.
  4. Dragon Touch M10X Camera Replacement: 4 단계, 이미지 1/1
    • Using a J0 phillips head bit, remove the single 1 mm screw from the rear facing lens cover.
  5. Dragon Touch M10X Camera Replacement: 5 단계, 이미지 1/1
    • Using a J0 phillips head bit, remove the single 1mm screw from the front facing camera lens cover.
  6. Dragon Touch M10X Camera Replacement: 6 단계, 이미지 1/1
    • Using a plastic opening tool, pry the rear facing camera out of its housing.
  7. Dragon Touch M10X Camera Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using a plastic opening tool, lift up the latch that attaches the camera's ribbon cable to the device.
    • Using tweezers, pull out the ribbon cable from underneath the latch.
  8. Dragon Touch M10X Camera Replacement: 8 단계, 이미지 1/1
    • Remove the camera strip from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph Rockcliffe
회원 가입일: 03/24/16
600 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-7, Catania Spring 2016 UMass Dartmouth, Team 4-7, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G7
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 389
