주요 콘텐츠로 건너뛰기
Dragon Touch M10X Power/Volume Button Replacement
필요한 것
  1. Dragon Touch M10X Power/Volume Button Replacement, Power/Volume Button: 1 단계, 이미지 1/2 Dragon Touch M10X Power/Volume Button Replacement, Power/Volume Button: 1 단계, 이미지 2/2
    • Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
  2. Dragon Touch M10X Power/Volume Button Replacement: 2 단계, 이미지 1/2 Dragon Touch M10X Power/Volume Button Replacement: 2 단계, 이미지 2/2
    • Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
    • Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
  3. Dragon Touch M10X Power/Volume Button Replacement: 3 단계, 이미지 1/2 Dragon Touch M10X Power/Volume Button Replacement: 3 단계, 이미지 2/2
    • Ensure your buttons look like this
    • If either the buttons or the button holes in the back cover are dirty, clean them.
    • If the buttons are cracked or broken, they will have to be replaced
  4. Dragon Touch M10X Power/Volume Button Replacement: 4 단계, 이미지 1/1
    • With the old buttons removed place the new ones in
  5. Dragon Touch M10X Power/Volume Button Replacement: 5 단계, 이미지 1/1
    • These buttons are held in by gravity alone so when reattaching the device back on to the cover, keep it upside down.
    • Secure the bottom of the device first before closing up the sides.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Eric Megna
회원 가입일: 03/24/16
333 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-7, Catania Spring 2016 UMass Dartmouth, Team 4-7, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G7
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 1,737
