소개
This project will result in an illustrated how-to guide on fixing a drawer roller bracket that does not close completely. By the end of this fix you will have a drawer that closes flush against the face of the furniture.
필요한 것
Clear out drawer of any contents. This will make the drawer easier to handle, with no mess or clutter.
To remove, pull the drawer completely open.
Lift the drawer straight up.
Remove the excess bracket. Make sure to remove parts of the bracket that do not contain holes. These holes are used for fasteners.
To cut a section, make sure you make perfectly vertical cuts for the remaining pieces to line up. To assure a straight line to cut, use a sharpie marker to mark a straight line.
다른 한 분이 해당 안내서를 완성하였습니다.
