주요 콘텐츠로 건너뛰기
Drawer Roller Bracket Replacement
필요한 것
  1. Drawer Roller Bracket Replacement, Drawer Roller Bracket Replacement: 1 단계, 이미지 1/2 Drawer Roller Bracket Replacement, Drawer Roller Bracket Replacement: 1 단계, 이미지 2/2
    • Clear out drawer of any contents. This will make the drawer easier to handle, with no mess or clutter.
    • To remove, pull the drawer completely open.
    • Lift the drawer straight up.
  2. Drawer Roller Bracket Replacement: 2 단계, 이미지 1/1
    • Remove the brackets on the drawer.
    • Some may have rivets, some may have screws. If there are screws a simple screwdriver will do the trick. If there are rivets use a drill the size of the head of the rivet and proceed to drill the head of the rivet.
    • When removing rivets with a drill, wear eye protection and be cautious.
  3. Drawer Roller Bracket Replacement: 3 단계, 이미지 1/2 Drawer Roller Bracket Replacement: 3 단계, 이미지 2/2
    • Measure the length of the internal track to the recessed part in the rear of the track.
    • This recess will hold the drawer completely closed when the wheel on the bracket reaches it.
    • Then measure the amount of bracket that needs to be removed. In our case, 2 inches will need to be removed.
  4. Drawer Roller Bracket Replacement: 4 단계, 이미지 1/2 Drawer Roller Bracket Replacement: 4 단계, 이미지 2/2
    • Remove the excess bracket. Make sure to remove parts of the bracket that do not contain holes. These holes are used for fasteners.
    • To cut a section, make sure you make perfectly vertical cuts for the remaining pieces to line up. To assure a straight line to cut, use a sharpie marker to mark a straight line.
    • Use a reciprocating power saw or a grinder with cutting wheel. I used a grinder because I found it to be easier.
    • Maintain eye protection, and gloves if necessary.
  5. Drawer Roller Bracket Replacement: 5 단계, 이미지 1/1
    • Apply JB Kwikweld to the remaining pieces of bracket. Mix equal parts of the mixture.
    • Discard the removed piece from last step.
    • When applying JB weld, use a small amount, I used a toothpick as an applicator.
    • Set time was roughly 6 minutes for the weld mixture to set.
    • Before adding weight to the drawer, allow the weld to fully cure. This will take 4-6 hours.
  6. Drawer Roller Bracket Replacement: 6 단계, 이미지 1/2 Drawer Roller Bracket Replacement: 6 단계, 이미지 2/2
    • Use a drill with a drill bit to make necessary holes for screws to sit and fasten the bracket. Use a drill bit slightly larger than shaft of screws, but smaller than the head of the screws.
    • I used a 3/32 drill bit.
    • Install new fastener screws to the bracket.
    • My build required 12 #6x1/2inch Philips screws. I used three screws on each end of the brackets and six screws on each end of the bracket.
    • The more screws used, the stronger the bracket is secured. (Two on the bottom of the bracket, and one on the inside of the track.)
    • If possible, use preexisting holes, and screws.
    • Sometimes screws protrude too far, you may have to grind the head of the screw slightly so it protrudes less.
  7. Drawer Roller Bracket Replacement: 7 단계, 이미지 1/1
    • Make sure the bracket is fastened securely, make any necessary adjustments.
    • You may need to grind down some of the JB Weld if too much was applied. Simply used a file or grinder.
  8. Drawer Roller Bracket Replacement: 8 단계, 이미지 1/1
    • Insert wheels on both sides of the drawer bracket into the opening behind the wheel on the track located in the furniture.
    • Close the drawer and make sure it opens and closes functionally.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Austen Schram
회원 가입일: 01/26/20
187 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 회원
USFSM-STEWART-S20S1G1
23 회원들
안내서 25개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 44
전체 시간: 414
