주요 콘텐츠로 건너뛰기
Dreamax DMX-ST7A Motherboard Replacement
필요한 것
  1. Dreamax DMX-ST7A Motherboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Position the tablet so the ports and screws are facing you.
  2. Dreamax DMX-ST7A Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the two 2.5mm screws using the Phillips #00 precision screwdriver.
  3. Dreamax DMX-ST7A Motherboard Replacement: 3 단계, 이미지 1/2 Dreamax DMX-ST7A Motherboard Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to assist in removing the back cover.
  4. Dreamax DMX-ST7A Motherboard Replacement: 4 단계, 이미지 1/1
    • Upon removing the back cover position the tablet as seen in the picture.
  5. Dreamax DMX-ST7A Motherboard Replacement, Motherboard: 5 단계, 이미지 1/2 Dreamax DMX-ST7A Motherboard Replacement, Motherboard: 5 단계, 이미지 2/2
    • Lift the black bars to expose the data strips.
    • Remove the data strips.
  6. Dreamax DMX-ST7A Motherboard Replacement: 6 단계, 이미지 1/2 Dreamax DMX-ST7A Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the three 2.5mm screws using the Phillips #00 precision screwdriver that is holding the motherboard in place.
  7. Dreamax DMX-ST7A Motherboard Replacement: 7 단계, 이미지 1/2 Dreamax DMX-ST7A Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove the three wires connected to the battery along with the speaker wires from the motherboard. Then remove the motherboard from the tablet.
  8. Dreamax DMX-ST7A Motherboard Replacement: 8 단계, 이미지 1/2 Dreamax DMX-ST7A Motherboard Replacement: 8 단계, 이미지 2/2
    • Install the new motherboard by soldering the speaker wires and the battery wires in their intended location. For additional soldering instructions please view this page: How To Solder and Desolder Connections
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stacey Mattila
회원 가입일: 03/18/15
543 평판
안내서 5개 작성하였습니다
Michigan Tech, Team 1-4, Lauer Spring 2015 Michigan Tech, Team 1-4, Lauer Spring 2015 회원
MTU-LAUER-S15S1G4
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 301
